help need info on rear end
Old Jul 19, 2011 | 10:25 PM
THE BIG BLOCK's Avatar
Default help need info on rear end
ok i want to go from 273 factory gear to a 373 gear, dose any one know what other ring and pinion gears will work besides 3rd gens or dose any one have one for sale
Old Jul 20, 2011 | 08:35 AM
blackz87's Avatar
First you have a 2-SERIES Carrier. Unless the 3:73 gear set is made for 2-seres (thicker gear) it will not work. You will have to seach for the thicker gear sets or change to a 3-Series carrier.
Old Jul 20, 2011 | 06:10 PM
microkid's Avatar
March 2011 ROTM
Technical User
most s-10 blazers have 3:73 gears and a gov-lok limited slip. you can purchase a junkyard rear for about $150, then have a professional swap the carrier and gears into your car. that is year dependant on your car, i dont remember what year camaro went from 26 spline axles to 28 spline. you could also try to find an f-body rear with those gears already installed
Wess001
Apr 5, 2015 12:42 PM
craby
Aug 11, 2012 09:13 PM
RFxCamaro
Jan 16, 2011 02:22 PM
z28rob18
Jun 16, 2010 10:27 AM
sepadowd
Sep 15, 2007 05:02 PM
