help car overheats on highway
i dont have a oil sender. removed it thought it was the problem got a mechanical tripod gauge and directly connected it in the oil sender hole. the thing is i might have kinked the line but dont see where.
i get a little tap in the engine but im chalking that to poorly adjusted rocker
i'm not tupid...lol ive been working on cars for a long time and just recently started getting into performance and such. i couldnt figure out why it was doing this is why i asked. but having limited time to work on her makes it difficult.
Oil pressure is low, You oil filter may be to restrictive what brand your using.
I had this happen to a few weeks ago....
Over heating - I'm going through the samething was going up to 235 now 180 to 210. I have install a hood scoop running dual fans and shroud.
With the hood up temp can ran around 165 to 170
My headers temp can run up to 400 to 675 so I'm working on getting the heat out.
Things may have the temp go up, oil to thick, timing off, stat not opening, exhaust restrictive, low coolant, fan not pulling enough air across the radiator,
carb to big for the motor/ not jetted right.
it sat for a little while. i now realize i have a coolant leak. and as far as running car with low oil pressure ...i believe i have a kink in the plastic line. it gives me no indication of actually having low oil pressure ( ticking) except for the gauge. my timing may be off cuz i dont have a timing sight to adjust. i kinda played it by ear when i timed it. rush rush if you know what i mean. i have an aftermarket timing cover and the sight would not line up. so if anyone knows where i can get one let me know. chevy dont offer it.
Artist_X
Aug 17, 2009 11:18 PM
