Help ASAP!!!!
Old Oct 31, 2006 | 12:23 AM
camaro89's Avatar
Default Help ASAP!!!!
hey guys im new names nick. i just got a v6 1989 camaro, now the guy sed it has eletrical problems which it does. the head lights work and locks work. windows dont work and horn doesnt work. he sed it got mess up bc of somethin to do with the trunk lock, i have no idea. i tried to crank her over she sounds like she wants to go but theres 1 problem. when i try to crank her she sounds like your doing it with a dead battery. but i kno for a fact the battery is not dead bc it was on a battery chager at boost, and i tried 2 different batteries.
does any one got any ideas??
Old Oct 31, 2006 | 12:25 AM
shnormo's Avatar
Default RE: Help ASAP!!!!
Sounds like you might have a bad realy or starter selenoid or a bad ignition switch.
Old Oct 31, 2006 | 12:30 AM
camaro89's Avatar
any way to check which one??? or do i just got to guess and replace??
Old Oct 31, 2006 | 12:31 AM
shnormo's Avatar
Voltimeter
Old Nov 4, 2006 | 03:38 AM
FlufyTiger's Avatar
Check continuity on cables and connections in the starting/charging system. As for charging the battery, trickle is the way to go if you think it's dead. A fully discharged battery will not take charge at more than 2 amps for well over 12 hours, no matter how many amps you throw at it.
spr203
Apr 29, 2009 08:38 AM
skatr128
Apr 24, 2009 01:54 PM
ScottD
Jul 29, 2007 11:45 AM
73 T Top
Jun 6, 2007 08:22 PM
mysrt4ownsyou
Oct 14, 2004 08:17 PM
