Heater Core
Old Aug 28, 2007 | 08:02 AM
EqualizedCustoms's Avatar
Default Heater Core
this might be a stupid question to everyone here. but i need to get my heater core out of my camaro.
wheres it located and how hard is it to get it out??[8D]
thanxs
matt
Old Aug 28, 2007 | 09:14 AM
rockin85's Avatar
Default RE: Heater Core
if its a 3rd gen, its under the dash on the passenger side. i replaced mine not too long ago. it takes a good 4 to 6 hours depending on if you know what your doing. unhook your heater lines from your engine compartment , then slowly take apart your dash, take your time when you do it because i broke a lot of things and it was a pain trying to fix them. there are about 4 screws you need to take off from a black box. youll know when you see it. the cover comes right off but when you put in the new core do it slowly so you dont bend the pipes. when its in, make sure it works before you put everything back in, the cores can be bad sometimes. it woulld save you the hassle of doing it again.you can do it with out takeing apart the dash but its a lot easier to get to them this way. youll need to take out your center consule too because the screws that hold down the dash are everywhere[:'(] its not that bad if you have the time and your patient with it. good luck.
Old Aug 28, 2007 | 10:11 PM
thats a lot of work 4 one lil thing. that suxs[&o]. i aint a very patient person either. hopefuly nothing goes wrong or i might end up breakin stuff. i am a hot head.[:@]. this is my first camaro so i am just learning. do i have to take the dash cover off and remove the speaker???or is everything right on the passenger side of the car? ( I Never Had to take a Heater Core out of anything before) there any step by step instructions out there???
Old Aug 29, 2007 | 12:29 AM
84 z .....'s Avatar
get a camaro manual.........there is all kinds of nifty stuff in them.
[align=left] [/align]
Old Aug 29, 2007 | 09:02 PM
350rs's Avatar
March 2008 ROTM
agreed, for this job inparticular, even my haynes manual was VERY helpfull. Little tips and whatnot that i wouldnt have thought of. Knowing nothing about changing a core, i had mine out and back in the car in about 6 hours, includeing two runs to the auto store for various thing, plus a run to get a then g/f. Who for some reason wanted to be there..
2kMaro
Nov 12, 2011 06:30 PM
albo1989
Jul 26, 2010 05:16 PM
mbizzle33
Oct 7, 2009 05:06 PM
95Z28pit
Sep 18, 2007 07:01 PM
BradsCamaro
Apr 27, 2007 06:33 AM
