Headlight Alarm
Old Oct 13, 2008 | 07:42 AM
Colby90's Avatar
Default Headlight Alarm
Restoring 89 IROC-Z. One problem is there is a warning sound when the lights are turned on. This happens with the key in or out, on or off. Where is the buzzer so I can disconnect it? Thank you. Colby
Old Oct 13, 2008 | 08:07 AM
Default RE: Headlight Alarm
Just stick your head under the dash and follow your ear.
But, why do you want to disconnect it? Do you leave your headlights on with the engine off that often? If you drive somewhere early in the morning where you need lights, and it gets light out by the time you arrive, it's easy to forget about having the headlights on. The chime could save you from ending up with a dead battery someday.
Old Oct 13, 2008 | 08:22 AM
Colby90's Avatar
The alarm sounds any time the key is turned on, this is annoying when driving. I can’t pinpoint where the sound is coming from just by listening and have hearing in one ear only.
Old Oct 13, 2008 | 09:40 AM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
ORIGINAL: Camaro 69
It is a good idea to build the habit of always turning your lights on. It's the first thing I do after starting my cars, and I've never forgotten to turn them off. It makes you more visible even in full daylight, and you can never be too visible
And I can't find my Haynes manual or I'd be checking in there to see if it'll say anything, sorry :/
Old Oct 13, 2008 | 12:56 PM
ORIGINAL: Colby90
Aaaah! Makes sense now. I looked in my repair manual and couldn't find it mentioned. I'll have to look at the wiring schematics, it should show there.
Old Oct 13, 2008 | 02:44 PM
hurley870's Avatar
I had the same problem. That alarm was going off whenever I had my lights on, weather the key was in or not, waether the car was on or off. It was a blown fuse for my dash, once i replaced it, everything was fine
Old Oct 13, 2008 | 03:15 PM
MadMikeZ28's Avatar
The convinience center where the alarm is located is behind the dash about where your right knee would be. Kinda hard to see. Really have to sick your head under there. It will also have other relays like the hazard and horn relays.
Old Oct 14, 2008 | 04:14 PM
Colby90's Avatar
Thank you very much
Colby90's Avatar
Thanks for the help
Fitzs
Apr 19, 2011 06:14 PM
POLOGREENZ28
Mar 29, 2010 02:42 PM
MochaCaliGirl
Aug 6, 2007 03:15 PM
rschick
Feb 10, 2007 07:30 PM
Saint_Ali
Aug 31, 2006 10:02 AM
