got a question about 1986 camaro Z28
Old Nov 6, 2006 | 04:44 PM
MadMikeZ28's Avatar
Default RE: got a question about 1986 camaro Z28
Your info is a little incorrect. For one a Posi (aka positraction a chevolet trade name from the 60's) and a Limited Slip are ONE and the SAME THING.
What you ment its a Open rear.[sm=chairshot.gif]
Your info is a little slow. Read the post above yours.
FLUFFY
I also had an inbred hillbilly tell me the same thing years ago and I'm in California so it must have spread!
Old Nov 14, 2006 | 10:17 PM
1983camaro's Avatar
ORIGINAL: ScottD
Slip a jack under the rear diff, lift, and hand spin the wheels. If they both spin, you gots posi. I know its more than you wanted to do, but its the only way to be sure.
ok , i jacked up the rear end last friday , and turned the driver side wheel back wards, and then the passenger side turned turned forward.
Old Nov 14, 2006 | 10:50 PM
FlufyTiger's Avatar
No posi for you. It's an open rear. You can get a torque locker from summit for about $300 to fix that. Just replaces your old carrier, and it's a pretty simple install.
sam.maeder
Mar 18, 2014 09:33 PM
86Z28Cam
Jan 29, 2014 06:04 PM
vzfox
Sep 23, 2007 10:26 PM
ROADBLOCK
May 12, 2007 03:56 PM
Dawn
Feb 1, 2006 06:45 AM
