gen4 rear in a gen3
Old Dec 9, 2009 | 09:46 AM
bd92rs's Avatar
Default gen4 rear in a gen3
can anybody here that has done this swap tell me how they got the parking brake cables to work. i am going from a gen3 drum brake rear to a gen4 disc brake rear.
thanks
brad
Old Dec 9, 2009 | 10:33 AM
350rs's Avatar
March 2008 ROTM
i havent done it yet to know 100%, but ive been told to get the e brake cables for the 90+ models.
Old Dec 9, 2009 | 05:44 PM
grarudfir's Avatar
Good post. I appreciate it.
Many thanks to ur post. I love it.
Old Dec 9, 2009 | 05:48 PM
91ralllysport's Avatar
lol sounds a little sarcastic to me
Old Dec 9, 2009 | 05:53 PM
350rs's Avatar
March 2008 ROTM
yea no joke. **** off.
Thats what ive been told, dont like it? SHOVE IT!
Old Dec 11, 2009 | 08:12 PM
microkid's Avatar
March 2011 ROTM
Technical User
dont forget to remove the metering valve and replace the proportioning valve under the master cylinder. if you dont, your rear brakes will lock up much sooner than the front, and will cause the car to handle bad under light braking while cornering.
Old Dec 12, 2009 | 06:43 AM
blackz87's Avatar
4th gen rears are a direct swap, however the rear axle housing is 4" longer overall. You will also to replace the Proportioning valve and make sure to get the parking brake cables for the 4th gen rear (present ones will not work). Your 3rd gen wheels may also be a problem, but some people say they are not (wheel back spacing is different between the two).
I thought about a 4th gen rear, but instead went with a 1989 BW 9-bolt with the pbr rear discs. Worked out better in my case.
Old Dec 12, 2009 | 10:47 AM
bd92rs's Avatar
thanks for the info
the reason for looking at the gen 4 rear is to open my options because around where i live gen 3 parts are getting hard to find expecially the disc brake posi rears
btw; would i need the gen3 or the gen 4 proportioning valve
Old Dec 13, 2009 | 04:17 PM
microkid's Avatar
March 2011 ROTM
Technical User
you would probably be better off with the 3rd gen proportioning valve, but i dont know if there is a difference. you could also just get an adjustable proportioning valve. that way you could change the braking balance to your liking, and if you go to the drag strip, you could turn down the rear brakes to allow for an easier burnout
Old Dec 13, 2009 | 09:10 PM
350rs's Avatar
March 2008 ROTM
and theres always line lock. If i get into it enough i will install one of those on mine, seems like a pretty straight forward install.
scottrc
Dec 28, 2010 08:32 AM
libertyforall1776
Nov 10, 2007 03:04 PM
LightlyToasted6
Aug 9, 2007 01:33 AM
