gears
Old Mar 3, 2007 | 06:20 PM
92camaroRS's Avatar
Default gears
I was considering getting some 3.73s. I was looking into 4.10s but someone said i wouldnt get any traction off the line? So which would be better? Also any ideas of how much a place would charge to install gears?
Old Mar 3, 2007 | 06:26 PM
blackz87's Avatar
Default RE: gears
$500/700 plus parts for around another $400/500. Not cheap.....
Old Mar 3, 2007 | 08:29 PM
350rs's Avatar
March 2008 ROTM
Default RE: gears
anything you can do on your own, do it. a shop will overcharge buy 200% at times to make the extra money. if you have the ability, even if it takes awhile, do it yourself.
Old Mar 3, 2007 | 09:52 PM
shnormo's Avatar
Default RE: gears
3.73 if it's still driven on the streets. It is also better traction off the line with a stock suspension.
Old Mar 3, 2007 | 09:58 PM
85z285.0's Avatar
Default RE: gears
I agree 3.73's would be better if you're still going to drive it on the streets. 4.10's will give you a nice launch but while cruising you'll be at a higher RPM.
Old Mar 3, 2007 | 11:20 PM
Abyliks's Avatar
Default RE: gears
i have 3.73s and i really wish i had 4.10s, i tach 2500 rpms about 74-80 (not sure, never got the speedo corrected) but i rarely drive on the highway, gas milage went down probably 2-3 mpg, its my DD to, you may also need a posi if you dont have one, id recomend the detroit true trac
sepadowd
Aug 4, 2011 07:59 PM
91camaro350
82-92 V8 Tech
Aug 5, 2010 10:28 AM
gfrench
Jun 19, 2010 10:16 PM
1bad96Z28
Jun 9, 2007 09:12 AM
