Gas smell.. scaring me
I've noticed lately that whenever I fill the tank, it reeks of gasoline outside the car. I do not see anything dripping underneath however. Normally when i drive a few hours later the smell is gone but sometimes still there the next day.
It almost smells like it's coming from towards the front of the car and not the back near the tank.
I've yet to crawl under and check all the fuel lines, but if it was the lines I would assume the smell would stay the entire time regardless of whether it was full or not.
Anyone have any ideas why it would smell like gas only on a full tank? I'm not dripping gas from the nozzle or anything outside of the car or anything.
Thanks,
Bez
Thanks,
Bez
could be a line off or cracked from the evap system. there is a canister under the hood, should be driver side front, behind the headlight. thats the charcoal canister that absords fumes while the car is not running and allows them to be consumed once the car is running. check the lines going to it and follow them to the tank.
