G80 limited slip swap from a monte
Old May 29, 2008 | 03:31 PM
sewerrat's Avatar
Default G80 limited slip swap from a monte
I recently aquired an 87 Monte carlo ss with a 305 a/t that I'm planning to strip down because the body is rusted out. I noticed the rpo code for the rear end is a G80 (limited slip). I haven't removed the covers from both the Monte and my 88 Camaro to compare if the limited slip will interchange with my open carrier. Does anyone know if the Monte's G80 willswap into the 88 Camaro? I also read that the G80 is a gov-loc style carrier. Are these any good for moderate built engines? Is it worth my time? Thanks guys.
Old May 29, 2008 | 04:45 PM
blackz87's Avatar
Default RE: G80 limited slip swap from a monte
RPO G80 was the common code for a Limited Slip rear used by GM. As far as I knon the 10-bolt rears were used only on 3rd & 4th gen cars. So parts may NOT interchange.
Old May 29, 2008 | 05:57 PM
MadMikeZ28's Avatar
ORIGINAL: blackz87
The 10 bolt rears are found in lots of vehicles. Pick ups and cars alike. Its just as time progressed the rear drive platform thinned out. [&o]
bohuntr
May 24, 2023 08:22 PM
lightningcruiser
May 27, 2012 07:54 AM
tttttt
Jun 5, 2011 01:33 PM
bbailey4life
May 14, 2006 02:05 PM
97_Z28
Mar 2, 2005 09:22 AM
