fusible link
Old Jun 30, 2008 | 11:03 PM
bigjim's Avatar
Default fusible link
OK the big block is in and running. the only issue we have is the headlights does anybody know where the fusible link is located. I checked the fusible links up by the radiator on the passenger side all were OK. also checked the switch there is no power there and the switched tested good any thoughts.
thanks Jim
Old Jun 30, 2008 | 11:17 PM
MadMikeZ28's Avatar
Default RE: fusible link
on the starter wires
Old Jun 30, 2008 | 11:32 PM
bigjim's Avatar
OK thanks. I put in a mini hitorque starterI hopeI can get by the header to check it out. Not much room in there now.;-)
Old Jun 30, 2008 | 11:37 PM
MadMikeZ28's Avatar
Even with the mini hitq huh
Old Jun 30, 2008 | 11:56 PM
bigjim's Avatar
even with the hitorque. those engine swap headers from hooker are huge and we have a low profile Milodon 7 qt pan on itto boot.we got the summit hitorque the wires face the oil pan if they faced the header I could get a socket on it stupid hi torque[:@]
Old Jul 1, 2008 | 12:04 AM
MadMikeZ28's Avatar
well given your posting in the third gen that must be what you have and there is not much room in there for some of the stock parts. I did a 97 4.3 in my mom's 84 S10 and it had a mini starter as stock OEM from an Astro van that I got some parts off of. Thank goodness to. A standard one would not fit in there because of the control arm.
Old Jul 1, 2008 | 12:20 AM
bigjim's Avatar
yup I put a 454 into a 91 rs it had a 3.1. I tested a purple wire comming from the starter and it had no power this might be the culprit. If it is i thinkI'll cut and splice it to the power terminal up front with a fusible link screw taking that starter backout.
Old Jul 1, 2008 | 12:30 AM
MadMikeZ28's Avatar
I think purple is it. I remember now I did this very same repair for head lights not working on my brothers car.
BUT
I gotta see some pics of that Big Block in there.
Old Jul 1, 2008 | 08:31 AM
black89rs's Avatar
wanna see some to......post em.............................
Old Jul 1, 2008 | 10:21 AM
MadMikeZ28's Avatar
Well we know why he does not have room for a starter or headers now anyway
