Fuel Question
Old Jun 29, 2010 | 03:54 PM
jcase350's Avatar
Default Fuel Question
What is the pounds per hour for stock or OEM fuel injectors?? Thanks in advance.
Old Jun 29, 2010 | 04:13 PM
blackz87's Avatar
Stock GM FI 85-92
305 TPI 19# FI
350 TPI 22# FI
Old Jun 29, 2010 | 08:25 PM
jcase350's Avatar
Since I have a Iroc-z w/ 350 and the OEM injectors is 22lbs/hr....is it better to buy the 21lbs/hr or 23lbs/hr injectors since they don't sell 22??
Old Jun 30, 2010 | 07:25 AM
blackz87's Avatar
If you can't find 22# injectors, I would go with the 23# ones. See how the car runs?? You may get away with just adjusting the fuel pressure regulator or a new prom for the ECM.
Worse case you may run rich.
Old Jul 1, 2010 | 07:15 PM
microkid's Avatar
March 2011 ROTM
Technical User
hm, thats odd, i cant find a listing for fuel injectors either at 22lb ratings. id go with the 23lb and throw an exhaust system on it, that will even it out!
87STROKER-Z
82-92 V8 Tech
May 16, 2011 05:06 PM
lookin2buy
Jun 3, 2008 02:51 PM
SilverBullet5
Nov 25, 2007 03:11 AM
1985RS
Apr 3, 2007 04:50 AM
sewerrat
Jun 15, 2006 06:53 AM
