fuel pump in my 89?
Old 02-17-2006 | 07:52 PM
beast85's Avatar
Default fuel pump in my 89?
i have an 89 camaro with the 350 tbi i am putting a 383 into it and was curious if anyone knows if the original is an in line or in tank fuel pump. im going to a carbuerated engine so it will be set up different anything anyone can tell me would be a great help. john
Old 02-17-2006 | 08:10 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: fuel pump in my 89?
89 should be in tank.
Old 02-17-2006 | 10:04 PM
The fuel injection pump is putting out way too much pressure for a caburator. You can try finding a different pressure regulator or replace the pump with one designed for carbs.
Old 02-18-2006 | 12:55 AM
89/383stroker's Avatar
i have a 89 camaro with a carbed 383 i just have the original fuel pump with a holley fuel pressure reg.
Old 02-20-2006 | 08:37 PM
beast85's Avatar
i was plannin on puttin a new fuel pump and regulator in it, i was just curious if it was in tank or in line, im goin to try and make it an in line fuel pump was curious about it though. thanks.
Old 02-20-2006 | 10:28 PM
beast85's Avatar
also i was wondering 89/383stroker, how much was the fuel regulator and how hard was it to install? do you ever have any problems with fuel pressure or anything of that sort?
Old 02-22-2006 | 06:10 AM
ORIGINAL: beast85
my regulator was install with the motor but i looked at it and it looks like a primary and a return line connected to the regulator and a single line to the carb, hope that helps
jon_uscg2001
08-25-2011 12:23 AM
nehidustin
06-28-2010 07:30 PM
carmodder
82-92 V8 Tech
06-23-2008 12:50 PM
BlueKitsune
10-05-2007 07:54 PM
johnson3034
05-25-2007 09:35 PM
Quick Reply: fuel pump in my 89?
