fuel
Old Aug 9, 2007 | 09:03 PM
450r44's Avatar
Default fuel
i got a 87 tpi 350, its got miles on the motor. its gettin over fueled really bad, like to the point where the cylinders are filling up with gas and leaking into the oil. i took out the fuel pressure regulator and its brand new. im goin to check the fuel pressure with a gauge but it seems like it has like none, when i press on the valve the fuel comes out a bit. can it be possible the pump went bad? im not sure, if anyone has had this problem pleaseeee post, i wanna drive my car again....... HELP PLEASE!!!! any ideas are welcome!!!
Old Aug 9, 2007 | 11:02 PM
may83's Avatar
Default RE: fuel
worn rings?
Old Aug 23, 2007 | 01:25 AM
shell29chevy's Avatar
Default RE: fuel
Fuel injectors bad and if there is fuel in the oil- save yourself a huge headache and replace engine.
Kendagenius
Feb 5, 2017 12:23 PM
mrfreez
Jan 21, 2011 11:58 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
