First Project...will need all the help I can get
Old Mar 7, 2011 | 12:30 AM
Linacre's Avatar
Default First Project...will need all the help I can get
Alrighty so just traded my bike for 1982 z28 with a rebuilt 350.
I want to get this out of the way...that I have a very short span of working on cars....I can do crotch rockets and cruisers but this is my first car project. So just assume I know nothing and tell me every little detail...I wont be offended.
Things to fix
1) When starting, usually have to try a few times and pump gas. Cranks and rolls over fine just doesnt seem to catch right away.
2)Once it does start, usually will not idle and stalls out, after multiple tries and revving...it will idle.
3) speed and tach do not work...will a simple replacement fix this?
4) brakes are verrry squishy...but will stop just not as fast as i would like. I belive I just need to bleed the lines.
Im pretty sure all of this is a easy fix with just some replacements and an overall cleaning of parts but please let me know! Thanks.
Old Mar 7, 2011 | 12:34 AM
Linacre's Avatar
Also....I can turn the ignition switch without a key in it and will start....
Old Mar 7, 2011 | 08:13 AM
torque_is_good's Avatar
sounds like a project vehicle to me, not a daily driver.
anyway, welcome and please don't go away once you get it running
First things first, get a mechanics mirror and read the stamping on the back of the block
then, using your internet connection, compare the casting #s and determine if it really is a 350. Many sellers simply say it but it's in fact a 305.
As for the running issue, the simplest thing to check is the timing. If yu don't have a timing light then go get one.
You should also replace the fuel filter.
If it isn't either of those, then you are looking at the carb as the suspect
It's an internal combustion engine
you need
air
fuel
spark
that kind of simplifies things doesn't it?
You should toss some plugs,wires, rotor and dist cap at it as well as fuel filter, time it and see where you are after that.
It's a 29 year old vehicle and I'm sure it isn't documented as to what is in it and what's been done
I'm restoring an 89 and the future buyer will know exactly what's in it and what was done
Old Mar 7, 2011 | 12:52 PM
djs383's Avatar
To address the tach: Typically on those pre-1990 it is because someone swapped an ignition component and didn't correctly wire that back into the tach. Get a wire diagram and figure out which is + and -. for example, my 87 pink is + and white is -. negative is used for the tach if no filter in place.
Speedo: my cable actually just broke yesterday, so either its a cable, or the gear in the transmission (drive or driven could be stripped). Or, once again, if it were a swap job, it may not be the correct trans for that year.
Get us a VIN number, that might help ID what was original to that car in 82. Sounds to me like it would have been a 305 CFI, or carb(assuming a z28) then a 76MM 4speed, or a TH200. If it were not a Z and just a base coupe, it have had the L4, V6 with that trans combo, or the V8's I listed earlier..Good luck
Old Mar 7, 2011 | 03:47 PM
age84's Avatar
March '09 ROTM
Just a few other things to think about if is a fuel problem it might be the fuel pump going out if it times out alright check your choke i do believe that it is carbed
on your brakes when you are bleeding them check the your flexable brake lines for any cracks or leaks. old lines will give the the same soft brake feeling.
As for the key issue just replace the tumbler with a new key it shouldn't be a problem for that year
Old Mar 7, 2011 | 10:50 PM
Linacre's Avatar
Yes this is definately not a daily driver, I have zero intentions of ever taking it on the actual road. I just wanted something to play with and learn some stuff. Thanks for the help, Ill check out the Engine casting number and see if its really a 350. And ill get a vin for you djs.
Old Mar 8, 2011 | 12:40 AM
Linacre's Avatar
can you give some some quick step by step to check the timing...and fix it if its off.
Old Mar 8, 2011 | 06:36 AM
ScottD's Avatar
FAMOUS LAST WORDS. Welcome to our addiction. I bought mine almost 5 years ago with the intention of a quick winter project..........now I wont give her up for the world. Welcome aboard.
Replace your carb, bty. Its probably full of junk. Spending 250 on a new carb will be well worth the investment.
Old Mar 8, 2011 | 09:47 PM
Linacre's Avatar
haha Thanks scott, I actually already replaced the carb...first thing I did!
skyfreakmg
Dec 12, 2011 10:38 AM
onlymesince1989
May 6, 2010 07:00 PM
may83
Aug 10, 2007 04:36 PM
wizard
Aug 8, 2007 08:40 PM
