a few newbie questions
hi i have a 1992 rs with the 305 tbi and 5 speed. its the lowest output v8 model. i was just wondering what kind of 5 speed is it ie brand model. also, i was looking to get an exhaust cutout to be wayyy loud and i was wondering what size do i need. the exhaust is stock except a different muffler. also, i want to pitch thelimitied slipand get posi with a 3.73 gearratio. i was wondering what i need to know to getthe correct model. iehow many splines is the axel. im pretty much a newb, all ive done is anew chip, and rippid out the air intake and got a non drop aircleaner and took out the spacer, ripped thehood insulation and the weatherstripping, and a new clutch.if youguyswouldcare to take the time toprovideexact links that would be REALLY appreciated!! thanks a bunch!!!
RE: a few newbie questions
Tremec makes your transmission. Its known as a T-5. its what i have in my 89 RS, but in front of that i have a crate 350. Stock pipe is 2 1/4" for your exhaust.
your thermo is located at the front of your intake manifold, when you replace it have a replacement gasket with you. As the old one will probably tear in half, or into about 20 pieces... Its under the Thermo houseing, easiest way to find it is to follow the upper radiator hose to the intake, it mounts up to the thermo houseing. Take the two bolts out, pull the old thermo, put the new one in after you clean the parts for your new gasket, put the new gasket on, and then bolt your housing back up. that simple, takes about 15 min if your new to it. Also, let it cool down before doing this, i dunno about you, but i dont like burning my hands....
