Extremely Puzzeling check engine light results!
Old Nov 8, 2009 | 11:47 PM
Irock ZZ's Avatar
Question Extremely Puzzeling check engine light results!
My 86 Iroc has a check engine light on majority of the time (sometimes shuts off for short periods). When i plug in the GM "Diagnostic Tool" the check engine light flashes indefinately instead of flashing a code! Help!
Old Nov 9, 2009 | 05:56 AM
is it pausing at all?
Old Nov 9, 2009 | 11:00 AM
Your check engine light should flash once, pause, then flash twice (that's the default no ignition signal code since the engine is off). It will do that three times. Then if there is an error code, it will flash a certain number of times, pause, then more times. It will also repeat that three times until the next code if there is one.
Are you saying it blinks constantly with no pauses at all (as Craby asked)?
Old Nov 9, 2009 | 02:33 PM
Irock ZZ's Avatar
at first it would blink with no pauses at all. i just went out for the 4th time and finally code it to flash the codes. 34, 36, 44
best way to reset and see if the come back?
Old Nov 9, 2009 | 03:42 PM
Disconnecting your battery for a few minutes will wipe the error codes from the computer.
Did you look up the codes? They're there for a reason, either from a permanent or intermittent problem.
Old Nov 9, 2009 | 08:48 PM
Irock ZZ's Avatar
they seem to be related to a maf issue and o2 sensor. ive heard something about a burnout relay for it? cant seem to find it anywhere.
bchbmjohn9
Sep 2, 2010 06:08 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
91ralllysport
Sep 22, 2009 03:04 PM
My01Z28
Oct 11, 2008 03:47 PM
BlueKitsune
Sep 14, 2007 07:00 PM
