engine temp. sensor?
Old Jul 11, 2008 | 02:22 AM
sewerrat's Avatar
Default RE: engine temp. sensor?
My 88's temp sensor(ECM) is on the drivers side of the water outlet top rad hose. The temp sender switch (Gauge) is on one of the corners of the cyl head. This one might be hidden by the a/c bracket or rear firewall. Wire colors are as Mike described.
Old Jul 31, 2008 | 09:45 AM
hshawn31's Avatar
well after amonth, i finally found the old part and got the new one in. I am waiting for a new brake line, so i cant test it to see if my overheating problem is fixed. if not, a new fan motor is next. thanks for th ehelp guys!
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
grover
Jul 12, 2010 04:35 AM
jhackett62
May 26, 2010 06:28 PM
3.4camaro
Sep 14, 2009 04:42 PM
hotrod
Apr 6, 2006 04:22 PM
