engine temp. sensor?
where is it on a 2.8l mpfi v6?
RE: engine temp. sensor?
at autoze.com its known as the temperature switch
You want the one for the computer? That would be in the intake manifold. It should have a yellow wire and if it has two a lack wire as well.
If you are looking for the temp sender for the gauge that is in the head with a green wire. |
lack wire eh? like, lilack? idk what color those are but im sure thats not it.. lol
i have a sensor with a yellow and black wire right next to my coolant temp sensor, but according to my book thats the temp sending unit/sensor. Is the engine temp. sensor underneath the plenum? i tried to use a light to look underneath it but all i saw were fuel lines and injectors.
Look for the wire colors. The temp sensor for the computer is the one with the yellow and Black wire (better 350rs?) That one only send a signal to the computer. The one for the gauge would have a green wire. It is usualy in the head near the exuast manifold. Maybe its not on yours but for the gauge it should be a green wire.
a little bit yes. thanks bro. lol
k thanks!!!
Its behind the thing located left of the doohicky underneath the watchamacallit beside the gadget and above the whatsit.
ORIGINAL: Jr. Mechanic Its behind the thing located left of the doohicky underneath the watchamacallit beside the gadget and above the whatsit. And when you start working on your car Garret here is a great place for you to shop. http://kalecoauto.com/index.php?main_page=index |
