Engine Stuff....
Old Oct 23, 2008 | 04:04 PM
Foxracing254's Avatar
Default Engine Stuff....
Hey guys I'm back lol and i'm kinda confused about some engine stuff. The guy I bought my car from told me it had a 350. Is there a way i can find out whether its a 305 or a 350? would it be stamped on the block somewhere, and where? Or could I use an engine VIN number? Also, It has a 4 barrel, I know that much, does that mean that it's a TBI? I think it would be nice to know what's under that hood lol. Thanks
Old Oct 23, 2008 | 06:36 PM
autopuppy's Avatar
Default RE: Engine Stuff....
on the drivers side of the block (rear) near the trans mount it should be stamped 5.0 or 5.7 . the vin # is also helpfull, hoping that no one has changed engines. sometimes it is also stamped on the sides of the block, in the area of the freeze plugs. you might be able to see these nos. from under the car looking up.
Old Oct 23, 2008 | 07:16 PM
irocktheIROC's Avatar
no its not a tbi, its a carb'd 4bbl.
Old Oct 23, 2008 | 07:23 PM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
The 350 was only TPI- so if it has a 4-barrel, it's gotta be a 305.
Unless the engine was swapped out.
Old Oct 23, 2008 | 07:28 PM
what year is it anyways?
Old Oct 23, 2008 | 08:23 PM
Sorry I should have posted the year... It's an '84 Berlinetta... from what I've found the berlinettas came with an optional 305. But the guy i bought it from told me it was a V6 car originally and then it was swapped. It was probably a mistake to buy the car without knowing that, but it was a fantastic deal. So I'll look for those numbers. Thanks guys!
Old Oct 23, 2008 | 09:08 PM
yeah 305 4barrel sounds about right for that car.
Old Oct 23, 2008 | 11:21 PM
74454bb's Avatar
May 2007 ROTM
run the vin and see if it was av6 car, then run the casting #'s off the block.
Old Oct 25, 2008 | 05:10 PM
where can i find the casting numbers?
madmank1
Nov 30, 2013 10:48 PM
Devin's camaro
Feb 22, 2011 08:50 PM
jermaghs07
Sep 13, 2010 03:43 PM
cplthomas
Aug 15, 2009 10:01 PM
n8_camaro_92
82-92 V6 Tech
Feb 2, 2009 11:30 PM
