engine dies when under load
I have a 82 camaro berlinetta i just did a 350 swap and it idels perfect and sounds good i have the timeing set at 13 deg advanced and when i put it in gear it just dies and then u turn the key and it starts right back up could this because of my carb or timeing??? idk what to do please help
What is the Idle set at? Choke stuck? Possible fuel pump/regulator issue? Doesn't take much fuel to keep an Idle. Floats not adjusted, starving the carb? I would say timing was close because it started and idled, if it backfired or pinged when it was running maybe. What carb do you have? All vac lines hooked up and not cracked?
