drive shaft problem
drive shaft problem
im doing an engine swap on a91 camaro it was 6cyl originaly that some one put a 305 with a 700r4 in the motor took a crap 5 min after i finished hooking it up so i swaped a 355 with a th350 shortshaft. ive moved the engine mounts back as far as i can and the trany mount lines up in the cross member but the drive shaft is to short by about 5 inches is there a drive shaft from another year or motor trans combination that will fit or do i need to get a drive shaft made?
