Doors
Old Sep 25, 2006 | 05:46 PM
Camaro86's Avatar
Default Doors
hey i was wondering if a set of firebird doors will fit on a camaro??
Old Sep 25, 2006 | 06:52 PM
FlufyTiger's Avatar
Default RE: Doors
All body parts from any F-Body will fit on any other F-Body from the same generation. Some will require replacing more than one part, but the doors will bolt right on no problem. They may look a little funny if the trim doesn't match, though.
Old Sep 26, 2006 | 12:42 AM
ScottD's Avatar
Default RE: Doors
Damn sagging doors. I spent 3 hours replacing my hinge bushings the other day. After all that work, it turned out to be the roller pin.
Now I gotta find a roller pin!! DOH!
Sorry Camaro86, I know Im not helping you much. Had to vent.
Old Sep 26, 2006 | 03:22 AM
MadMikeZ28's Avatar
Default RE: Doors
Firebird fenders and quarters are not the same.
ScottD
What bushings did you replace? Just the lower or did you find an upper kit? I had to replace my uppers and found a guy who makes shoulder bolts and bushings to fix em. Did not care for them too much but they work and were easier than a hinge. I think Napa has the roller where you grind off the swedged end of yours and knock it out then drop the replacment in and fasten it with a nut.
Old Sep 26, 2006 | 09:09 AM
FlufyTiger's Avatar
Default RE: Doors
True, but they'll fit the car if the surrounding parts are replaced. The bumpers and hoods aren't the same either, but they'll bolt up, and if everything else is changed to match, they do fit. I never said it was a good idea, I just said they'll fit.
Old Sep 26, 2006 | 04:48 PM
trailerparktrash2009's Avatar
Default RE: Doors
As far as i know..the doors should fit exactly the same..as for body parts the only difference between camaros and firebirds are the very front and the back area..
thebandit110
Jul 16, 2010 09:54 PM
Cody T
Jun 1, 2009 08:15 AM
Napaman08
Mar 16, 2009 11:53 AM
RockJay81
82-92 V8 Tech
Jul 17, 2008 12:52 AM
bugmenot
Feb 22, 2008 12:53 PM
