Dash Pad
Old Dec 14, 2006 | 08:19 PM
pookey_03's Avatar
Default Dash Pad
I removed all the bolts holding it on and it will move up and down. i can stick my arm under it it just wont come out. is there bolts in the back os some clips? thanks
Old Dec 14, 2006 | 08:56 PM
blkmgkcamaro's Avatar
March 2007 ROTM
Default RE: Dash Pad
well theres bolts in the defroster hole, under the dash pad, and probably in the middle air vent. did you get them all?
Old Dec 14, 2006 | 09:11 PM
pookey_03's Avatar
how the hell do you get to those
Old Dec 15, 2006 | 12:51 AM
FlufyTiger's Avatar
They screw in from the top. There are four of them, and a stubby screwdriver helps.
Old Dec 15, 2006 | 09:41 PM
MadMikeZ28's Avatar
There are two screws in each defrost vent and a number of them along the edge cloest to you. None in the vents. And I think there are tabs in the back and once the screws are out and you can lift the edge close to you pull it towards you.
augie1209
Apr 15, 2012 07:45 AM
augie1209
Sep 13, 2009 04:49 AM
93Z28joel
Nov 3, 2007 07:42 PM
79projectZ28
Oct 29, 2007 09:52 PM
Camaro86
Mar 2, 2007 02:59 AM
