a couple questions about a engine swap and cam.
Old Jan 25, 2010 | 02:40 PM
david1368's Avatar
Smile automatic cam
can i put a lt4 hot cam in my 1984 camaro without worrying about it shutting off when i put it in reverse? Im going to swap motors i have a v6 in it but im gonna to put a 350 in it.
If this helps the transmission is a 700 r4.
Old Jan 25, 2010 | 02:59 PM
so why would it shut off when putting it in reverse?
Old Jan 25, 2010 | 03:49 PM
david1368's Avatar
i figured with the low rpms it would
Old Jan 25, 2010 | 04:03 PM
Old Jan 25, 2010 | 04:08 PM
Are you concerned about having a wumpity-wumpity kind of idle? You can speed up your idle if necessary.
Old Jan 25, 2010 | 04:12 PM
david1368's Avatar
yeah thats what i was talking about
Old Jan 25, 2010 | 04:17 PM
shouldnt be a problem if its all set right.
Old Jan 25, 2010 | 04:53 PM
Just curious why the LT4 cam instead of an aftermarket flat tappet one?
Is the added expense of roller lifters and a cam position limiter setup going to be worth it?
Old Jan 25, 2010 | 09:27 PM
microkid's Avatar
March 2011 ROTM
Technical User
because some people would rather spend the $500 for the "lt4" cam, maybe because they heard from someone less informed that its what is needed to do.
Old Jan 26, 2010 | 06:19 PM
david1368's Avatar
If you guys could tell me a different way to get the lopey idle sound for cheaper i sure would appreciate it.i want it to have aggressive sound.Not to loud though.
