automatic cam
can i put a lt4 hot cam in my 1984 camaro without worrying about it shutting off when i put it in reverse? Im going to swap motors i have a v6 in it but im gonna to put a 350 in it.
If this helps the transmission is a 700 r4. |
so why would it shut off when putting it in reverse?
i figured with the low rpms it would
Are you concerned about having a wumpity-wumpity kind of idle? You can speed up your idle if necessary. |
(Post 396512)
Are you concerned about having a wumpity-wumpity kind of idle? You can speed up your idle if necessary. yeah thats what i was talking about |
shouldnt be a problem if its all set right.
Just curious why the LT4 cam instead of an aftermarket flat tappet one?
Is the added expense of roller lifters and a cam position limiter setup going to be worth it? |
(Post 396528)
If you guys could tell me a different way to get the lopey idle sound for cheaper i sure would appreciate it.i want it to have aggressive sound.Not to loud though.
