Couple questions
Old Oct 22, 2012 | 10:04 PM
syndealer's Avatar
Default Couple questions
I have a 91 RS v6 auto.
Been noticing when I accelerate sometimes there's bump or knock underneath right about were the shifter is. Doesn't always happen but noticeable when it doe's.
Also after I've been driving a while and everything is nice and warm the oil gauge fluxes. Doesn't seem to leak oil - that I've seen.
It's also been recommended that I flush my trans fluid. I have no clue if it's ever been changed but it doe's have a good color and doesn't smelled burnt.
Old Oct 23, 2012 | 08:14 AM
Edwardgp's Avatar
Check your transmission cross member bolts for tightness and your transmission mount on your first problem of the knock.
Old Oct 23, 2012 | 08:19 AM
Edwardgp's Avatar
The gauges on our cars are notoriously inaccurate. You can hook up a mechanical oil pressure gauge to check it out. I know it wont hurt anything to change your transmission filter and fluid, at least you will know when it was done.
Old Oct 23, 2012 | 08:21 AM
John4649's Avatar
I had a knock and it was a torn tranny mount a 7$ part at autozone
Old Oct 23, 2012 | 08:31 AM
juice+'s Avatar
i had that happen on my 92z28, i would accelerate and it sounded like something wanted to pop up thru my shifter, it was the tranny mount. The rubber was slit down the middle. Easy fix I believe its 5 bolts and the mount is off, put the new one on and the bolts back in and youll be good to go.
Old Oct 23, 2012 | 03:44 PM
syndealer's Avatar
Cool thanks, I'll check the trans mount and see if thats the prob
chase0990
Jul 11, 2010 10:08 PM
toxicat
Apr 6, 2009 01:29 AM
rpope904
Jul 6, 2008 04:11 PM
whammer3024
Aug 20, 2007 10:03 AM
redt_top
Mar 14, 2007 11:00 PM
