A couple of newbie Questions
Old Jan 6, 2007 | 07:56 PM
92CamaroUK's Avatar
Default A couple of newbie Questions
I have a new cat that has a pipe coming out of the side of it....
What' this for/connect to?
I've been told that I can remove the charcoal cannister that's situated to the right hand side of the engine bay. (This would be useful to create space for my CAI hose).
Is it just a case of finding where the hoses go to, unplugging them and blocking up the ends?
Thanks for your help.
BTW: I have a '92 Camaro RS (TBI).
Old Jan 6, 2007 | 11:24 PM
MadMikeZ28's Avatar
Default RE: A couple of newbie Questions
The tube in your cat is for the air injection. If you dont have an air pump on the car any more just plug the hole.
The fuel tank vents through the canister so you will at least ned to place that hose in an area where it wont get water in it. There is also a solenoid on it and if you must remove the canister leave the solenoid plugged in so you may not get a check engine light.
Old Jan 7, 2007 | 07:20 PM
92CamaroUK's Avatar
Brilliant, thanks for that.
Jerseyrider1119
Dec 2, 2011 07:51 AM
jds88z28
Oct 14, 2007 02:07 PM
rocker9
LS Series Tech
May 11, 2007 06:28 PM
asdfghjkllkjhgfdsa
Apr 25, 2007 04:58 AM
Cool_84_NOT
Jul 10, 2006 12:17 AM
