correcting speedo after gears
Old Jan 17, 2007 | 12:10 PM
Abyliks's Avatar
Default correcting speedo after gears
anyone know where i can get a speedo gear to correct the 700R4 for my 3.73s now?
Old Jan 17, 2007 | 03:03 PM
FlufyTiger's Avatar
Default RE: correcting speedo after gears
http://www.transmissioncenter.net/sp...n_______va.htm[/align][/align]Should run you about $20 plus shipping for new gears. You'll need your tire diameter handy to figure out what gears you need, so you might as well get it before you try to buy, if you haven't already.[/align]
Old Jan 17, 2007 | 03:24 PM
Abyliks's Avatar
im running a 26" tall tire so that would be a 43 tooth then? just want to make sure, i hate ordering the wrong parts and that sites confusing[:@]
Old Jan 17, 2007 | 06:22 PM
MadMikeZ28's Avatar
You may also need a sleeve. There are differnt ones for whatever gear you have or need. A long and a short. A small gear needs the long sleave to place the driven gear closer to the drive gear. Pull your gear out and see how many teeth you have then contact Speedometer Service Company and tell them what you have.
414-463-6660
www.speedometersolutions.com
A couple years back I got a gear for $8 and the sleeve and seal was $61
Old Jan 17, 2007 | 06:38 PM
MadMikeZ28's Avatar
I have a 44 tooth gear (grey, the colors are how you tell how may teeth) and a sleeve from my 700R4 I will sell you. $20 and I will pay the shipping. It is a plastic sleeve. The one I paid $61 for was aluminum.
Old Jan 19, 2007 | 01:19 PM
Abyliks's Avatar
ORIGINAL: MadMikeZ28
how much would that be off for 3.73s and what are you running?
Old Jan 19, 2007 | 07:50 PM
MadMikeZ28's Avatar
I cant say how far it would be off. It was in my 84 Z28 with a 3:43 and how ever tall the stock tires were. I replaced the rear with a LS that had 2:77 so I needed to change gears and that is why I have this one.
78 on my plate
Oct 2, 2011 02:11 PM
wiseguy
Jan 10, 2011 05:30 PM
Abyliks
Jun 8, 2007 11:38 AM
shnormo
Oct 16, 2006 11:56 PM
