code 42 stalling when hot and low battery voltage
so guys in continuation of my current problem my car will drive perfectly fine up until it gets hot then it will sputter and eventually die out i can let it sit until it cools and it drives fine again until hot, its throwing code 42 and when it stalls i see that the battery voltage is below 8 volts but when i fire it back up voltage goes back to normal, is this in anyway associated? i know someone told me a bad icm has similiar symptoms?
libertyforall1776
Feb 24, 2014 02:11 PM
