code 42 running sluggish
Old Jan 23, 2013 | 01:47 PM
87 camaro z28's Avatar
shame on electrical problems!!! lol and i ordered it im expecting it anyday now lol
Old Jan 23, 2013 | 01:52 PM
Realizing and admitting that electrical problems can be sneakier and more sly than we are might help to keep the frustration levels down......maybe!!!
Old Jan 23, 2013 | 03:28 PM
lol im still fighting with that one
Old Jan 25, 2013 | 02:47 PM
i have a question guys on ,y 87 z 28 the est line going from the ecm where does it run to?where does the est stop at or go into?
Old Jan 31, 2013 | 10:38 AM
microkid's Avatar
March 2011 ROTM
Technical User
should be a tan single wire along the firewall, usually by the heater box, or under the passenger side carpet taped to the wiring harness on the firewall. have you inspected the distributor drive gear? have you set the base timing? set the base timing when cold, let engine got hot, then check it again. if it moved, its an indication of worn distributor parts and the heat is affecting the timing. just had the same issue with a 90 blazer but with no cel. ran poorly when cold- had new cap, rotor, plugs, wires, electronics. progressively got worse. pulled the distributor after seeing the timing would move 6* between cold and hot and found the gear 2/3 worn through
Jelz28
Jul 20, 2012 11:00 PM
cloned25
82-92 V8 Tech
Sep 29, 2009 06:37 PM
fleshman77
70-81 V8 Tech
13
Jan 7, 2009 10:35 PM
crowe
82-92 V6 Tech
Aug 5, 2008 12:34 AM
auSStin
LS Series Tech
Aug 29, 2006 01:53 PM
