Carb Swap and new Intake
Old Mar 12, 2008 | 03:31 AM
pyrofire127's Avatar
Default Carb Swap and new Intake
I've got a 90' camaro RS with a 350 from an 88gm truck.
This might be already explained somewhere so could someone link me to a TBI to carb swap?
if not could someone help explain what could be done?
im new to carb so what would be a good performance carb i was told to aim around a holley 650?
and what Intake would work best with that? (none vortec)
Thanks guys
Old Mar 18, 2008 | 09:45 PM
91RS305ADAM91's Avatar
Default RE: Carb Swap and new Intake
edelbrock makes an intake for the newstyle chevy head for 87 and newer its a performer intake great for a street as for a carb bewteen and 600 and 650 will be great
[IMG]local://upfiles/12361/AA03AA9DAAF547B7B3545302D12763B6.jpg[/IMG]
Old Mar 18, 2008 | 11:33 PM
1990CamaroRS's Avatar
Fancy Sparkle
ORIGINAL: pyrofire127
Thanks guys
i wouldn't go anything over a 700cfm carb on a 350. i'm running a Holly 650, and it does just fine. i'm still running the intake that was on the motor when i bought it
Old Mar 19, 2008 | 01:31 PM
Jr. Mechanic's Avatar
August 2009 ROTM
I would go with an edelbrock performer intake if you are on a budget, if you want a little better one, the edelbrock victor jr. seems real nice. As far as the carb goes, I would go with a Holley street avenger 670 carb. Unless you have it cammed, that is plenty.
Old Mar 19, 2008 | 02:40 PM
ORIGINAL: Jr. Mechanic
I do have a heavy torque cam right now that i plan on changing out later on down the road.
I went to the Holley website and it had a "interactive carburetor selector" and it recomented for Heavy mods a 370 CFM Four Barrle carb Part #: 0-80670
http://www.holley.com/applications/C...lector/0-80670
This is the one
i dont know what would change but i was hoping it would have a "timing vacuum port" because i want to run an manual distributer with vacuum advance
Would this been a good choice?
Old Mar 19, 2008 | 02:42 PM
i looked up the Victor jr. and my only hesitation is that it says Power bands range from 3,500 to 7,000 rpm, on up to 4,500 to 8,000 rpm.
and i still redline at 5k so wouldnt i only be able to use the true power for 2k RPM?
Old Mar 19, 2008 | 04:10 PM
August 2009 ROTM
Honestly for the money, the edelbrock performer is the way to go IMHO. That street avenger carb is the exact one I am getting for my 350, even with a cam you should be alright. You will have stock heads, correct?
Old Mar 19, 2008 | 05:17 PM
yeah i still have stock heads, but i was thinking about the Performer RPM? would that be a good choice (not the Air-gap one)
and after a while ill be changing out the heads but i dont know what i'd change them to yet (good time in the future)
WIspartan1026
82-92 V8 Tech
19
Mar 9, 2013 03:49 PM
lopezlv2
Apr 6, 2009 06:24 PM
sesopha
70-81 V8 Tech
Feb 16, 2009 04:02 PM
19camaro78
Nov 27, 2005 04:29 PM
r0nin89
Sep 18, 2005 10:22 PM
