car not starting everytime with supercharger
Old Jan 14, 2007 | 02:05 PM
DJYoshaBYD's Avatar
Default car not starting everytime with supercharger
ok.... I have a fuel injected 89 IROC-Z with a Paxton supercharger.... The car used to be cool... then out of no where is started not starting.....
It starts fine in the first time of the day, then it warms up a bit, then it wont start.... let it chill for a half hour, then it will start... then when you shut it off, it wont start.... its very picky when it wants to start after it gets warm...
And yes, we already checked fuel pressure (OK), Spark (replaced wires, coil, etc.. now OK), and hooked up an OBD scanner to check if there where any codes or anomolies and we still cannot figure out this problem... anybody had this before?
Old Jan 14, 2007 | 02:29 PM
FlufyTiger's Avatar
Default RE: car not starting everytime with supercharger
Ignition Module. It's under the distributor, and has a wire of some sort plugged in to it (sorry I can't give more detail, but I haven't actually even looked at my Camaro in months) The last time I had this issue, I had to replace an ignition module twice. If it does fix the problem, and then it comes back, you'll likely need a new distributor.
Old Jan 14, 2007 | 02:39 PM
DJYoshaBYD's Avatar
so.. I think that it was replaced.... just out of curiosity, why would a bad distributer cause the ignition module to go out?
Old Jan 14, 2007 | 03:00 PM
FlufyTiger's Avatar
I'm not entirely sure why. I was young and inexperienced the one time I had to deal with it, and since then, I've never come accross it again. I would have to guess that something in the distributor was either shorting to it and overloading the circuitry or it was getting too hot for similar reasons, but when I replaced the distributor, I no longer had any modules go bad, and the car lasted untill a chewed through battery cable shorted out and caught the car on fire 6 months later.
Old Jan 14, 2007 | 03:20 PM
DJYoshaBYD's Avatar
ahhh...cool
Old Jan 15, 2007 | 01:52 AM
DJYoshaBYD's Avatar
anyone else have any ideas? Im not just trying to get one theory.... start naming things to check that cause this on these type of cars... Im thinking it might be MAS related.... but just my luck, probably not
Old Jan 15, 2007 | 02:11 AM
ghotachevy's Avatar
is it not turnin over good when it won't start like starter drag or spinnin but nothin
Old Jan 15, 2007 | 11:47 AM
DJYoshaBYD's Avatar
it cranks goog, and sometimes it will start to start, but then just keeps cranking.... Im going to check the ignition again and see if it went bad....
Old Jan 15, 2007 | 04:33 PM
dzroc's Avatar
fuel pump relays might be goin bad or a bad ground.
Old Jan 17, 2007 | 06:22 PM
Dan88IROC Z's Avatar
The car will start with a good or bad MAF sensor. However, it wouldn't idle correctly or drive correctly with a bad MAF.
Tim Weaver
Jul 2, 2014 08:40 PM
Logan47
Sep 22, 2011 08:28 PM
c4maro
May 17, 2011 07:42 AM
mttjacobsen
Sep 21, 2010 11:00 PM
