Cams...
Old Nov 16, 2008 | 01:05 AM
Jr. Mechanic's Avatar
August 2009 ROTM
Default Cams...
Next winter I plan on pulling the motor out of the camaro and building it up some more... A short list for ya':
Jegs 1.5 ratio aluminum roller rockers
Jegs aluminum race heads, 64cc combustion chambers, 2.05 valves, 195cc intake runners, assembled with .700 max lift, and angled plugs
Jegs noisy cam gear drive
Hedman long tube ceramic coated headers
Comp Cams hardened push rods
Edelbrock Elite tall valve covers and aluminum timing cover
Jegs 7qt aluminum drag oil pan, and high flow pickup
Edelbrock Torker II single plane intake manifold
Mr. Gasket full gasket set
Based on that info, plus my current specs (rebuilt engine, steel crank, forged pistons, high flow/volume oil pump, built 700R4, 2300 stall converter, .436 lift cam, holley street avenger 670), what cam would you recommend? Remember I want this to stay streetable and start during the winter, so im skeptical on how aggressive I can go. Here are the two I have really been looking at:
http://www.jegs.com/i/Comp+Cams/249/12-250-3/10001/-1
http://www.jegs.com/i/Comp+Cams/249/12-246-3/10001/-1
Would either of those be too aggressive? Do I NEED to get a higher stall converter, if not, what would the negative effects be? Anything else you suggest, or anything different you would suggest from what I listed above? I plan on doing this over the entire next winter, and ive already bought the roller rockers.
bobc04
May 6, 2009 01:22 AM
94camarokid10
Jan 28, 2009 09:14 PM
FearThisInc
Oct 10, 2008 04:31 AM
Camaroslpss
LS Series Tech
10
Sep 17, 2007 06:43 PM
Camaroslpss
LS Series Tech
Jul 30, 2007 09:14 AM
