broken power steering reservoir
Old Apr 3, 2007 | 07:16 PM
SomeCallMeFonzi's Avatar
Default broken power steering reservoir
well a friend and i were working on my 83 when he accidentally broke the power steering reservior on the plastic part that connects to one of the hoses. is there any way to fix this without getting a whole new reservior or am i pretty much screwed cuz id like to keep it simple instead of running out to a junkyard cuz there are none within about 20 or so miles of my house and i havent been able to find a store that can order them.
any suggestions??
btw i still have the piece that cracked off where the hose connects to the reservior so if there is anyway to put those two together it'd be great or if i could at least find a piece that would adapt to the hose and the reservior
Old Apr 3, 2007 | 08:08 PM
MadMikeZ28's Avatar
Default RE: broken power steering reservoir
You have a plastic resovour? Its not steel? Is it a remote one not part of the pump?
Old Apr 3, 2007 | 08:19 PM
yea its plastic its in the front of the bay on the drivers side right on the side of the fan shroud
Old Apr 3, 2007 | 08:29 PM
MadMikeZ28's Avatar
O I C
Epoxy! But I doubt that would work well. If it is something you dont want now I do have a steel one out of an Astro van. It uses about a 5/8 hose and has a smaller return that can be plugged on the side.
Old Apr 3, 2007 | 11:37 PM
that would be great but the only thing is how would i get it here cuz PA is kinda far away from Cali and i was hoping to get it fixed by friday for the weekend
Old Apr 3, 2007 | 11:49 PM
MadMikeZ28's Avatar
ORIGINAL: SomeCallMeFonzi
That you would be screwed on.
Old Apr 3, 2007 | 11:53 PM
yea maybe i could try to put something on the two pieces to fix it cuz im dying to drive it again
hopefully it will work
royrois
Feb 15, 2013 02:28 PM
shane1617
May 22, 2011 08:35 PM
BasicConcepts
Feb 9, 2010 12:11 PM
bgill99
May 4, 2009 11:53 PM
