Bought engine!!
Old Mar 15, 2009 | 09:06 PM
chevy21's Avatar
Default Bought engine!!
well i bought my motor today you guys. 350 but its a 2 bolt though im kinda sad but i dont think ill be racing the car often so it should be ok?
Old Mar 15, 2009 | 10:16 PM
Gordon24Camaro's Avatar
i think 2 bolt is a disadvantage if you want to achieve over like 400 hp, 399hp is enough to bury 99% of cars out there.
4 bolt mains aren't necessary unless you're bumping the engine up to some higher compression ratio numbers and intend on revving the **** out of it. For a relatively "normal" engine, 2 bolt mains are more than sufficient.
Old Mar 16, 2009 | 11:24 AM
chevy21's Avatar
Default well
im just looking to build a 383.. street/strip car it will be ok for that right? I mean if it only hit the strip maybe once or twice a year?
Old Mar 16, 2009 | 11:26 AM
chevy21's Avatar
and if it came down to it. i would just buy 4 bolt mains and drill hte block and have it threaded prob solved
Old Mar 16, 2009 | 11:49 AM
Intrepid781's Avatar
No, a 2 bolt should be just fine for that. My wife's brother built an alcohol injected drag car and I think he said it had 700 horses and it was a 2 bolt. It was one of those really sleek long cars that only one person can sit in. I cant remember their names though.
Old Mar 16, 2009 | 06:40 PM
It's called a Rail Car.
Old Mar 16, 2009 | 09:41 PM
Jr. Mechanic's Avatar
August 2009 ROTM
I would not use a 2 bolt main block for a 383. If you want to build off that block, get the 2->4 bolt main kit from Eagle. You will have to have the motor line bored then, and honestly good 4 bolt blocks are a dime a dozen, so you could probably pick one up cheaper than it would cost to convert that 2 bolt.
Old Mar 16, 2009 | 09:51 PM
350rs's Avatar
March 2008 ROTM
but those splayed 4 bolt main caps are a bit stronger. TOTAL over kill for what your wanting however
Randy Bilyea
Mar 27, 2013 06:53 PM
Davila2000maroRS
May 16, 2012 11:00 AM
Mornieaux
82-92 V8 Tech
May 7, 2009 05:46 AM
TorqueTilla
82-92 V8 Tech
Apr 28, 2007 09:29 PM
95camaroproj
Apr 1, 2006 11:44 AM
