black filter valve looking thing?
ORIGINAL: MadMikeZ28
I thought you had TPI. I am so lost.
I have TBI. I will go take a look right now to be sure and tell you were it goes.
Didn't we go over this on another thread he started? =p
ORIGINAL: motor tec
i have the one that looks like a carb with the two injectors....
fluffy you are right. This is the same member we got confused with on another thread I believe.
There should be a metal line on the front, left of the intake next to the number 3 if you have the stock intake. It goes back along the length of the valve cover and that is where the black filter hooks to.
ok so were the line ends an sticks straight up in the air (towards the hood) the filter go's there? an witch way does the 90' angle go? an then where does it connect to? the brake booster?
the line points to the air near the back of the valve cover, the filter goes straight into that and the angle on the filter points to the booster. then a hose from the filter to the elbow that goes into the booster.
