Best tune up?
Old Apr 8, 2011 | 03:23 AM
Drexg's Avatar
Default Best tune up?
I want to do the best tune up I can on my car. What type of spark plugs should i get? Is there a specific brand thats best for rotar and cap. What else should I replace?
Old Apr 8, 2011 | 07:48 AM
torque_is_good's Avatar
you are going to get opinions that are all over the map. If you spend $100 for spark plug wires does that mean they are better than the $35 set from Summit? Is MSD the only dist cap to get? If so, how did the 3rd gens make it for so long out of the factory without MSD components?
what's the best................well, anything is better if your plugs/cap/rotor/wires need replacement. Go to the local parts store and just get what's on sale.
Old Apr 8, 2011 | 08:07 PM
microkid's Avatar
March 2011 ROTM
Technical User
i run ngk plugs in all of my vehicles. i have had the most luck with them. dont bother with the bosch platinum +2 and +4 plugs. they do nothing special and cost a lot. get a decent set of wires and a new cap and rotor and call it done
Old Apr 9, 2011 | 04:45 PM
Drexg's Avatar
Yeah the guy that had it before me did a simple tune up on it before I bought it but I have already put enough miles on it. I'm thinking of getting some AC rapidfires, Msd spark plug wires, K&n filter, and a fuel filter. Then after that an oil change with royal purple.
Old Apr 9, 2011 | 07:27 PM
djs383's Avatar
Thats some good quality parts, but I would agree with the above posters. Regular old autolites, or NGK (great quality), normal cap, rotor, wires and name brand oil is fine. You will spend enough on those parts for three tune ups or four tanks of gas.....at least. If it were a performance motor or a fresh rebuild, then sure, but a stocker....no difference over normal brands.
Old Apr 10, 2011 | 08:44 PM
microkid's Avatar
March 2011 ROTM
Technical User
dont waste your time with royal purple. its not a race car. also, the molecular structure of synthetic oil is smaller. the little oil leaks you have now will increase to larger leaks when running synthetic. if you want a good oil, run mobile super 5000 10w-40. its about $14 for a 5 quart jug and will clean out any sludge in the motor. i wouldnt bother with the k&n filter either. expensive and allows more dirt to pass than a paper filter
auto
Nov 1, 2010 10:29 AM
forevverlost
Mar 8, 2010 07:31 PM
uncool
Aug 23, 2008 12:53 PM
kirks11
Aug 12, 2008 08:11 PM
