Best Intake for the vortecs?
Old Jan 11, 2010 | 11:14 PM
ScottD's Avatar
Default Best Intake for the vortecs?
Its time to buy the intake........Im looking for a good intake that will provide monstrous flow on the bottom to mid range. There seems to be a few different brands putting out basic 'performer' style manifolds. Any suggestions or comments? Summit has a store brand for less then 150 bucks, the 'Brock equivalent is shy of 200.....
Old Jan 12, 2010 | 12:38 AM
Jr. Mechanic's Avatar
August 2009 ROTM
Old Jan 12, 2010 | 05:03 PM
ScottD's Avatar
Jr, once again I ask if you are on JEGS payroll? 8*)
The first manifold you showed was a 'air gap' model, the other two werent. Ive been told (maybe erroneously ) that 'air gap' manifolds are better suited for race cars that spend more time at WOT than a street car. The produce more power in the upper RPM ranges. Any merit to this?
Old Jan 12, 2010 | 07:26 PM
microkid's Avatar
March 2011 ROTM
Technical User
can't say ive heard that the air gap is for high rpm use. the idea is to separate the incoming air/fuel charge from the hot oil splashing on the underside of the intake manifold, as well as the coolant passing through the lower part of the manifold. now that weiand is advertised as a high rise manifold, which im thinking that after the air cleaner is installed, probably wont fit under the stock hood, but im not 100% on that
Old Jan 12, 2010 | 08:20 PM
ScottD's Avatar
Oooooh, dont give me a reason to cut the hood and install a scoop.......
Old Jan 12, 2010 | 10:16 PM
August 2009 ROTM
What he said about the air gap. If I end up getting a new manifold that's probably what I'll get.
I didn't notice the Weiand was a high rise manifold. That would cause hood clearance issues. I have a standard rise Edelbrock Performer RPM combined with my Street Avenger and a drop base 14x3" filter. I come within 1/4" of hitting the hood.
I'd say the standard run of the mill Edelbrock Performer or equivalent will be fine for you Scott. No matter what you get you won't see too much of a difference in power either way.
Oh yeah, no I'm not on Jegs' pay roll. lol. I just have spent thousands of dollars there with zero mix ups, bad products, lack of customer service, etc. Their customer service is exceptional. Last time I had a question about something the guy turned out to be a yachting fanatic (I work for my father's hydraulic business that deals mainly with mega yachts), and we got to talking back and forth about my line of work.
Old Jan 13, 2010 | 09:24 PM
ScottD's Avatar
Yeah Ill probably get the Edelbrock or Weiand. Id love to get the highrise but I really dont wanna deal with hood clearance issues right now.
My ONLY complaint with JEGS is that their website is hard to navigate and not nearly as user friendly as Summit. Thats the major reason why I do more business with Summit. If you keep sending me these links...I may be swayed!
Old Jan 13, 2010 | 10:53 PM
August 2009 ROTM
Honestly that's the exact reason I don't use Summit. I've always found their website more difficult to navigate than that of Jegs. I've been fooling around on Jegs since I was a little kid though, so that may be why.
Old Jan 14, 2010 | 09:54 PM
If you want a good manifold with better bottom end power, then steer clear of any intake that isn't a dual plane! Open plenum intakes are strictly for mid-top end range engines. The air gap can be found in open plenum or dual plane intakes, so the air gap part is just to deliver cooler fuel to the engine.
I personally have nothing against JEG's, but also find Summit's site much easier to navigate. Plus anytime I've had a shipping delay issue with Summit, or one of their suppliers; Summit has refunded all my shipping costs. That's pretty much sold me on them.
For $211 I'd get their air gap intake!
http://www.summitracing.com/parts/SUM-226019/?rtype=10
crimson09
Dec 15, 2018 07:07 AM
carid
Vendor Special Buys
Jan 20, 2015 07:08 AM
tuletymeZ28
LS Series Tech
Aug 22, 2010 12:12 PM
ScottD
Nov 7, 2009 10:38 PM
gozzy341
Sep 14, 2007 11:22 PM
