Battery draining? any ideas???
I had the same problem last spring. I checked all the fusible links turns out one was bad. I replaced it and problem solved. Camaro 69 is right don't try and replace it with a fuse you'll end up melting the wires.
libertyforall1776
02-24-2014 02:11 PM
