Battery charging during the winter
Old Dec 20, 2011 | 10:04 AM
drjgarage's Avatar
Default Battery charging during the winter
I have a 1991 RS that will be sitting during the winter with little road time. I have a trickle charger dor it. Should I disconnect the terminals from the battery or just put the connectors on to the battery with it connected to the car? I'm worried about the computer not getting any power for a long time and the same time having it get power from the charger being hooked up.
Old Dec 20, 2011 | 11:38 AM
Either way will work, it's up to you. Leaving the battery connected won't do any harm, nor will disconnecting the battery harm the computer. The one "safety" with disconnecting the battery, is there's no chance of getting an electrical short or fire (from hungry varmints, chafed wires, etc.) if the car is stored away from your sight. Oh, and with the battery connected with the ignition key off, the list of things that do get power is limited.
Old Dec 20, 2011 | 08:51 PM
torque_is_good's Avatar
no worries about the computer and you probably already know why
have you heard of ROM, PROM, EPROM ?
Those have a program stored in them which does not disappear when power is gone
RAM on the other hand is temporary
today, you also get the term "flash memory" which is used on many gadgets. The OS resides in flash but the gadgets still need RAM
Dana
Sep 3, 2013 11:29 AM
jmantra
Feb 16, 2012 12:02 AM
89camaroMan
Feb 10, 2010 03:02 PM
jlala
Oct 21, 2009 06:36 PM
6v49der
Oct 15, 2007 01:16 PM
