Bad U joint or ?????????
Old Oct 16, 2005 | 01:17 PM
ringo234's Avatar
Default Bad U joint or ?????????
I recently got an 89 IROC 5.7 TPI. It has a posi-rearend not sure the ratio.
When I hit the gas hard something in the rear of the bangs.
Is this the U Joint or maybe excessive end play in the rear end?
Thanks
Old Oct 16, 2005 | 10:45 PM
waytofast's Avatar
Default RE: Bad U joint or ?????????
check your transmission mount. when mine broke i thought it was something in the rear for a while.
Old Oct 16, 2005 | 10:53 PM
It could be the transmission mount or thr torque arm bushing on the transmission tailshaft.
Old Oct 17, 2005 | 12:17 AM
ringo234's Avatar
Thanks I'll check it out.
Gorn
Jun 8, 2015 11:13 AM
Tearl99
May 25, 2014 02:20 PM
stea
Sep 13, 2011 10:22 PM
