any tips on aiming headlights?
as the subject says.....ill be aiming my headlights tonight for the first time since replacing front clip including core suport
i was thinking aiming the inners properly an jus aiming the outers to shine a little further out
The way we used to set them was for the beam to drop one inch in 25 feet. If your headlight is 24", to the center, off the ground then with 25 feet between the headlight and a wall make the beems center 23" high. And just off to the right.
