another build up(cop car)
Old Jul 12, 2009 | 12:24 AM
NEVERLETITDIE's Avatar
Default another build up(cop car)
well guys im back unsatisfied with my performance of my 305 tbi that i juss finished this winter its not doing the job =p
well im looking at this 94 or 96 caprice cop car that has a 160k miles on it and im thinking about rebuilding the motor and installing my cam that has 493intake 497 exhust at 112 lobe seperation and i want ur guys oppions
it will also be carbed instead of fuel injected. im looking to make it run a high 12 just a street car and sense it has so many miles im probaly going to have to bore it and line hone im going to install all new bearings prolly run with a flat top piston and do larger valve springs i also will run with a 2800 stall and 3.73 rear gears do you think i will push my goal?
i also have a set of 305 h.o heads with the 58cc and that would be without flat top pistons but they are a lil on the small runing side i think i should stay with the 350 heads
so any suggestions would be great
thanks in advance guys
Old Jul 12, 2009 | 10:34 AM
Mesosneaky's Avatar
Wink
ya stick with the 350 heads. I was told the 305 h.o. have higher compression but wont let your 350 breathe like it needs too. I had the same question as I'm doing the same thing
fbodyrs96
Apr 19, 2014 01:59 PM
nasstySS
Mar 21, 2012 08:42 AM
Oil guy
Apr 17, 2009 07:41 PM
1981TypeLt
Feb 19, 2009 10:21 PM
gomez101380
82-92 V8 Tech
Nov 27, 2008 11:14 AM
