Advice / tech help please
Old Jan 13, 2010 | 07:33 PM
linebacker53's Avatar
Default Advice / tech help please
I have been presented with the opportunity to get a 89 camaro rs w/ a 305 crate motor and built 700r4 for $1200. BUT the fuel pump is bad. Is this an easy fix? should I buy it? thanks.
Old Jan 13, 2010 | 08:08 PM
350rs's Avatar
March 2008 ROTM
pumps arent easy, but they arent hard. if you want to work at it a bit, buy it.
Old Jan 13, 2010 | 08:15 PM
As said, it's not hard, but it is time consuming. And with this model, you will need to drop the tank to do it the right way. Don't let anyone convince you to do it the "trap door" way (I already tried), unless you have the facilities to double flare steel fuel lines to connect them back together. I have pics of when I did mine if you want to see what you're in for.
But yeah, if the car is in good shape, buy it.
95slvrZ28
May 26, 2015 08:23 PM
RayRayZ28
Feb 16, 2011 12:14 AM
rayistfaaku
Jan 21, 2011 07:32 AM
1981camaroz28
Oct 23, 2007 05:44 PM
