95 camaro 3.4 V6 starting issues
Old Apr 7, 2014 | 05:41 PM
skylarpena's Avatar
Talking 95 camaro 3.4 V6 starting issues
Hi,
I purchased this Camaro a few months back and it was working perfectly, then a few weeks back it started to have starting issues. Some days it will start perfectly, other days it will not start for anything. I've put a new fuel pump, fuel pump relay, ignition control module , bypassed the Vats, new battery new plugs and wires, new coil packs. All it will do is crank and crank and crank. Idk what to do next, a little guidance would be much appreciated.
Old Apr 7, 2014 | 07:11 PM
when it won't start is when you need to test things. check for spark, use noid light to check for the computer telling injectors to fire.
pmccall2
Dec 11, 2010 12:09 PM
bansheeboy261
Jun 19, 2010 09:21 PM
bansheeboy261
Jun 19, 2010 09:19 PM
trevora42
82-92 V6 Tech
Feb 9, 2009 06:54 PM
Chevyguy2
Feb 6, 2009 03:30 AM
