95 camaro 3.4 V6 starting issues
Hi,
I purchased this Camaro a few months back and it was working perfectly, then a few weeks back it started to have starting issues. Some days it will start perfectly, other days it will not start for anything. I've put a new fuel pump, fuel pump relay, ignition control module , bypassed the Vats, new battery new plugs and wires, new coil packs. All it will do is crank and crank and crank. Idk what to do next, a little guidance would be much appreciated. |
when it won't start is when you need to test things. check for spark, use noid light to check for the computer telling injectors to fire.
