92 RS V8 305 remanufactured engine
Old Feb 20, 2010 | 02:02 PM
scifly25's Avatar
Default 92 RS V8 305 remanufactured engine
I've been driving my current 92 Camaro RS Anniversary Addition for about 4 years and have grown very fond of it. Sadly the engine recently threw a piston rod and is no longer usuable. Should I buy a remanufactured V8 305 engine to replace it and if so what kind of trouble might I run into while the old one with it?
Old Feb 20, 2010 | 04:03 PM
Boosted8vfury's Avatar
I dont like my title
shouldnt be an issue if your just change out the blocks tried any places to see if you could just get a lt1 swap probly be cheap and then you would know atleast it will go in like the old one came out.
Old Feb 20, 2010 | 09:18 PM
scifly25's Avatar
Sadly I can't find a cheap lt1. I'm looking to go with a 5.7 350 TPI. Is it possible to swap this into my 92 RS V8 305?
Old Feb 20, 2010 | 09:21 PM
im nto quite sure but some one that has done this will chime in but id say it be the same besides the 350 and 305 being diffrent bore and stroke and all.
Old Feb 20, 2010 | 10:08 PM
scifly25's Avatar
That would great if that is true, I'd rather not have to worry about about getting a new/different transmission to put in it.
Old Feb 21, 2010 | 12:46 AM
carguy68ssrs's Avatar
I bought a long block 350 from Kragen auto 5yrs ago and put it in my 92RS which of course came with a 305. Still runs like a champ, thing was cheap too at the time, only 900 bucks
Old Feb 21, 2010 | 07:58 AM
scifly25's Avatar
were you able to use the same transmissions and other parts?
Old Feb 21, 2010 | 11:40 AM
Yes All small block Chevy's of the same year are the same on the outside,just different bores and strokes till you get to the LS engines, then its different
Old Feb 22, 2010 | 01:39 PM
microkid's Avatar
March 2011 ROTM
Technical User
is your engine tpi or tbi? i suggest as well upgrading to a 350, and just about everything will work. you will need to change injectors though. if its tpi, you will need 22lb injectors. if its tbi, im not sure what type of injectors it needs, but you could just use ones off a 350 truck, just make sure the replacement engine is for the 92 year. during the late 80s there were numerous minor changes made
teerts
Jun 9, 2014 09:19 AM
DarkHart
Aug 14, 2011 10:54 AM
Nosida
Aug 16, 2010 08:23 AM
Chevykicksbut
Oct 28, 2009 07:14 AM
hbobh99
Jul 18, 2009 07:33 AM
