3.4 remanufactured, or get the old one machined?
Old Aug 10, 2010 | 11:27 PM
Nosida's Avatar
Question 3.4 remanufactured, or get the old one machined?
I have a 95 3.4 I took it to an oil change shop and they messed up and didnt fill it back up with oil, I drove it to work the next day and on the way home it started knocking. I have parked the car and am trying to decide what is the better idea. I would like to put something bigger in it, but I am a full time college student, so an ls1(plus new suspension, computer, exhaust, and probably tranny) is not in the budget. I can go and get a remanufactured engine from autozone for about what I can take the engine to a shop and get it rebuilt, any benefits to one over the other? (other than the numbers will match?) or if you have a better suggestion, let me know.
Old Aug 11, 2010 | 03:13 AM
the main reason to rebuild would be to build stronger and more power another would be you know its done right and if it isnt then you know who to blame. lol. soo if your trying to save money and time go with autozone. what kind of warrenty do they give and if you install what is it.
Old Aug 11, 2010 | 05:14 AM
If the shop is covering the repair their insurance should handle everything. Remanufactured engines are almost always cheaper then local rebuilds. If the engine ran dry your rebuild will be pricey.
Old Aug 11, 2010 | 08:17 AM
torque_is_good's Avatar
if the story is factual, then the shop had best be covering the repair.
Old Aug 11, 2010 | 08:35 AM
I worked at a tire place while I was going to school. They replaced 2 engines due to mistakes while I was there. The only choice the owners had was what dealership did the work. One of the cars was still under warranty so the work had to be done with GM parts to keep the warranty. The other got a reman with a one year 12K warranty through the dealer. The insurance company does not want to deal with new engine problem that can be traced back to this so they push the whole thing off to the dealers. They also supplied the customer with a rental car while their car was in the shop.
Old Aug 11, 2010 | 08:09 PM
Nosida's Avatar
haha yes the story is legit but it happened a year ago. I had to leave town two weeks later for college. I got back in town this summer and am trying to get this handled. The shop owner claims since I dont have regular maintenance records with them on the car that they wont replace the engine. I always did it myself, it was my toy so I did it. I was busy that weekend and let them handle it, and look what it got me... the warranty from autozone is something like 10-15k i think. and its good for a year.
Id like to make the engine more powerful, since I cant afford to sink a v8 in her right now, but I dont know what all that entails. I can work on cars, as far as swapping parts, or installing some aftermarket stuff, but I know nothing about taking the one I have and getting it set up to pump more power...
Old Aug 11, 2010 | 08:20 PM
3.4 is a good block and can produce some good numbers for a 6. i would do the reseach to set it up to better handle more power. pistons, ported heads, some good conecting rods, headers, cai, you know a few k extra worth of improvments. maybe stoke it up to handle some nos just in case. lol. then look at the numbers and think about if its something i want to do for that much. if so do it.
Old Aug 12, 2010 | 06:54 AM
1augapfel's Avatar
I recently finished the overhaul and reinstallation of the 3.4 in my 94. The engine was overheated and driven hot by the PO and a head gasket blew. RH head also had a small crack. Engine had 130k miles on it at the time.
I first tried to install a used engine to minimize down time and got screwed. Then I looked into a Jasper rebuilt engine -- about $2600 IIRC. I eventually pulled the original engine and had it rebuilt by a shop I trust. The engine was bored and decked, got new pistons, rings, bearings, oil pump, cam, lifters, etc. Cylinder heads were shaved a little and got a valve job. The shop assembled the short block. The shop bill was $2700.
I bolted on the heads (watch out for the head bolt issues!) and did the rest of reassembly/reinstallation. It is a big job and it took me months in my "spare" time LOL.
I wanted stock, bone stock, to keep things simple and reliable. I never considered a V8 swap becasue the car is intended for my 18 YO daughter.
I've put several hunderd miles on the car since last week when it was finished. The 3.4 is more than adequate to motivate the car so that makes me happy. I know the 3rd generation Camaros could get the 2.8 and that was kind of doggy.
Good luck.
Old Aug 12, 2010 | 07:02 AM
1augapfel's Avatar
Here are a few pics of the process.
Attached Thumbnails 3.4 remanufactured, or get the old one machined?-img_0430.jpg   3.4 remanufactured, or get the old one machined?-pb060047.jpg   3.4 remanufactured, or get the old one machined?-p4200039.jpg
Old Aug 12, 2010 | 02:36 PM
libertyforall1776's Avatar
I sure hope the oil change shop is paying for this...
Go for a 3.8L instead. ;-)
