92 RS issues
ok so i was on my way home last night and i was just about there when all of a sudden the headlights went off..raido died..all inside lights went off as well. So i try to see if theres any engine codes and there is none(besides code 12)...so then i try to fire it back up and it starts but i gotta feather the throttel for it to stay running..but its running super rough..I guess i dont get it..i drove the thing all day w/ no issues then just like flicking a lightswitch it dies...I NEED HELP...thanks
Think what a is battery function, hold a charge. Maybe the alternator is still chaging the battery but still is going out
I would be looking at it first. But if you have better ideas go at.
Well, i just had the beast fixed and all it was was a bad ground for the fuel pump!
Ok now i wanna know how hard it would be to put in a 350 in? I got a v6 so im lookin 4 more grit! Do i need 2 swap out trannys 2?
Wow! All that stuff you described in your first post and it was just a bad ground for the fuel pump??? I'll have to say I have never seen that before.
As for a V8 yes you will have to change the trans. Those small V6 are a 60 degree motor and a V8 is 90 so the bellhouse is different. As for fit, the cars came with V8s also so it should fit like a glove (unless you get it from O.J.) If you have to do smog or inspections, depending on what your state allows, you would have to get yourself a computer and a few other components that go along with a 350. If not there is a publication by Quikie Racing "How to Run 11 Second E.T.'s on a budget". I believ the book was intended for f bodys.
A bad ground to the fuel pump DOSENT RESULT in electrical problems. Let us know how much it cost you to get towed and the cost of new alernator.[sm=feedback.gif]
A motor swap into a v6 car, I would not even think about it.
Cheaper to go out and find a 350 car.
